Cheap printed circuit boards starting with 0,0375 Euro / cm2
Hello everybody,
I present you attached the cheapest manufacturing way, for single pcb layer ( home made ) with semi-professional look , starting with 0,0375 Euro / cm2.
Can be also tinned, the copper traces ....or even something like " soldermask " ( can be solder through "soldermask" applied )
You can see also some more projects of mine to bellow address:
https://www.dropbox.com/sh/gz4t8fdnt0ylfu3/Fia1FUt9Yu
If someone ( without technical possibilities and required time ) need to build a prototype board or very small quantity ( up to 10 pcs / pcb ) , please feel free to contact me to : msdesignerpro@gmail.com
I can deliver you all over the world , in cheapest way , through National postal mail services.
Kind Regards,
MSdesigner Pro
E-mail: msdesignerpro@gmail.com
Regarding file format for PCB's
Where are you from?
Do you need gerber files? I'm working with a light version (TARGET3001) and cannot convert to gerber.
Greetz
Hi Benson,
I am from Romania.
If you export as pdf .....jpeg ....etc and you mention the sizes at corners is OK ! ....We can talk more details if yo'll send me email with required file to : msdesignerpro@gmail.com
See you there ! :)
Some more printed circuit boards ( pcb's) , done it in last time can be seen it bellow:
Thanks Birger.
Now is clear for me.
No I don't make it on black pcb.
Anyway , I have seen that this " black pcb " is for UV manufacturing procedure.
My procedure is an original one .....and is almost the same as " serigraphic procedure "
So is not as common way to manugature the pcb's , as UV ( photo ) or toner transfer.
Yes ! Andrew , in fact you have right soldermask is to prevent......but in fact is not a "real soldermask " .......it's something like a glossy flux ( dried ) which prevent oxides of copper traces and in the same time you can solder through pads ( help soldering ) ..............and of course you must be careful to solder only on the pad's places.
All the best.
What is the purpose of a solder mask that can be soldered through.
I thought a solder mask was there to prevent soldering beyond the intended pad area.
Ordered five Fr4 tinned boards from Mihai and received them today.
They look really professional and I'm very happy with the result!
He finished them during weekend a couple of days after payment and shipping was really fast too!
I just wanted to write a good review here so you may feel confident about ordering from him. Communication via email was great, and it was a pleasure to deal with him.
I will not make through plate holes , because inquiry is under 1% !
The traces on FR4 ( better than CEM , XPC , if required many re-solderings) , are strong enough.
Re-soldering is helped if traces are tined from beginning.
Re-soldering " traces- pad's life" it depends of soldering skills ( soldering time , de-soldering time) , soldering temperature , de-soldering temperature.
If you want, we can talk more to : msdesignerpro@gmail.com
I can answer you much faster through above e-mail.
All the best,
Mihai
Do you have plated through holes?
How well do the traces survive removal of component lead and re-soldering?
Hello everybody !
Bellow you can see the latest pcb's done it on FR4 and CEM support.
Two of them, are tin plated.
If anyone without technical possibilities is interested, I can help him in fastest way , and cheapest way , including delivery all over the world with National Post Mail Services.
All the best,
Mihai
Hello everybody !
Bellow you can see my latest pcb's done it on FR4 and CEM support.
All the best,
Mihai
