Chip amp power supply- a beginners guide
Joined 2011
Hi everyone! I have a question about snubber capacitors. Do I put those before or after the rectifier bridge?
Another question is about varistor. I have transformer that outputs 25v-0-25v. I was thinking to put varistor rated at 60v across two coils. Will that work?
Attaching schematic.
Thank you all!
Joined 2009
Thank you all!
The snubbers are always between the power transformer & the bridge diodes. Using Quasimodo gives you the exact values;)
