Those Magnificent Television Tubes
The green/blk box sylvania 6ag5 with the dark carbonized glass are absolute gems in a line stage. Every time i compare it to other 6ag5, or really any other kind of tubes i have now they re-blow me away. I've been combing ebay for them for a bit now, have bought several matched pairs now too, and they are all in an entirely different league then anything else i have when it comes to soundstage presentation. even my 12ax7 circuits feel flat and dull to me now that ive gotten used to these little TV tubes. Im only running barely over 100v across the plates. They no joke feel twice as big in every direction as any other tubes i have. Some of you older tube and radio guys may have em lying around too maybe. Thats how i got my first box em them. Wish it had more of these one's though lol.
As triode > pentode as well for audio. More gain (if you need it), less THD, and a sounstagier soundstage (lol)
The linestage design im using is attached because why not. Forgot to draw the output off the coupling cap, but whatever lol.
Tube pic just to show what i mean by dark glass. They arent used. All the old green/blk box sylvania 6ag5 tv/radio tubes look like this. All have carbonized glass, but some have black plates some dont. They all sound unreal though. Some of the yellow box sylvania 6ag5 have crbonized glass, some dont, i havent tried any of them yet but have some on the way.
I'm a beginner with amp design and tubes. But i've been training an ear in the mixing and mastering side of things for quite some time, and i know an impressive soundstage when i hear it. These dark glass 6ag5 as triodes are pretty nuts. The more i learn and play with, the more i feel like i somehow lucked out and stumbled into a hidden gem right off the bat or something. Nobody uses these for anything unless they have an old radio that uses them, and most my 6ag5 are pretty nothing special tubes... But man, these dark glass tubes are a newfound love like i haven't had in audio in many years. Spec for triode class A operation is right on the data sheets for them too. When it comes to some other tubes (cough* 12ax7 cough* cough*), a set that sounds like these do is not cheap. These run about $10-15/matched pair, ive bought a few pairs on ebay already. I got a lot of 9 of them with 2 matched pairs in it for $20 shipped. The box of 6ag5 given to me free had 12 of these sylvania's in it. Won't be long and ill have enough for the rest of my days. (Maybe some of you have some and dont want them ;) )
Reactions: 1 user
Only my view; Generally, I found Syvania video line tubes often rather noisy; partition noise in pentode & microphonic for audio. Currently, I am using the 12BY7/HG7 (have loads of them) as audio diff drivers and had to spend several evenings sorting out to get reasonably matched pairs (best set up as triodes, nice with 25dB gain). After much sorting found the Philips ECG version the most consistent performers. GE did also well, but RCA and other brands were rather noisy and microphonic. But makers for these didn´t stipulate these types to be used for audio, so didn´t strive for min noise & mictrophony in the 1950´´sand 60´s TV market, unlike the later ECC8xx series specifically for the audio market end product.. What I have found that tubes for TV (often having larger cathodes) are best run at somewhat higher currents than other types, as after several days stabilizes the characteristics.
Keep at it.....it´s all a great kudos & curiosity!
Bench Baron
Reactions: 1 user
Bench Baron
Im talking about a specific era of sylvania 6ag5 technically, and only certain one;s from that era. But that is still actually very true, about of the roughly 20+ of these i have and have tested now in circuit, almost all of them have huffed and puffed for the first 20ish mins ive used them. On almost all of them it goes away permanently after that first 20-30 mins period though. No idea at all what's up there, maybe there are a few gas molecules that have to get charged and thrown to the oxide layer before they perform properly. The darkglass Sylvanias are as old as 70 years at this point. I do have 3 or 4 that stayed hissing at me.
I also haven't been using them as pentodes, i much preferred them sonically as triodes immediately so i haven't used them much in pentode circuits. The difference between using these as pentodes vs triodes in an audio circuit is akin to pulling an invisible sheet off your speakers, so to speak. I've played with several of these sharp cutoff pentodes now, and i don't really care for any of them in an audio circuit being used as a pentode. They all sound and measure better as triodes when used for audio, but so far the dark glass sylvania 6ag5 are the only ones worth writing home about.
If you are in a noisy environment the darglass tubes def benefit from being shielded as well and youll prob toss 1 or 2 /10 for noisy heaters and 1 or 2 /10 for being huffy and puffy. But they are also incredibly inexpensive when it comes to tubes that soundstage this well, so that doesn't bother me personally.
You won't get a lot of gain from them (i think rated 36 gain as triode), but you will get a frankly ridiculous soundstage that's not quite like anything else ive heard.
Honestly i've stopped playing with my other circuits, and ive even stopped window shopping for new gear and tube types/circuits because i don't need the gain, i was just after that glowing holographic tube soundstage. These tubes are my reference when it comes to tube soundstage at this point.
Reactions: 1 user
Similiar effect.....sort of running in. one could say....I´m using the rather flightly 12HG7 as Williamson diff driver with CCS of-50V, 20mA per tube and 10K anode loads with 400V supply, that sets the anodes at approx 200V (wrt cath), a near replica of the slaughter conditions of glass TV days. As mentioned, to tame the wild pentode, the only way I found for audio was set up as triodes. Wading through the heap and set them up into rough pairs. I noticed after the hard run-in for a few days, the diff voltage stabilized. so these tubes DO require a bit of "push and shove" to stabilize their characteristics.
The unfortunate thing is, I may have culled out quite a few tubes which were quite out of any matching prospect into the "Rej" box (fortunately returned to the loft) which I thought were hopelessly gassy and noisy, but all they needed was a little time for themselves to get going..........Just like us humans !
The 12BY7 (more common) is a sim but slightly lower mu tube but maybe I should find a circuit for these gems. There does seem to be alot of tubes in the 7-12W rated anode class. Although I was brought up in the early 1960´s Uni days on tubes, I´m beginning to shun other tubes more commonly used in audio circuits as I´ve sensed better around.
On aesthestic grounds, the group of nicely glowing large cathodes does make an attraction. As a retired designer. I love the impression.
Bench Baron
Regarding the 12BY7A, (Frank's 12BY7A. This one is almost a power pentode (PD= 6.5W) and likes Bigvolts (no shortage of that in a colour TV chassis) and some stiff plate currents. Not surprising as this type was intended for video amps. You need some stiff current to charge the CRT interelectrode capacitance at 4.0MHz rates. You can get the screen voltage down, and with it, plate current. (I have these in my collection, but so far haven't needed all that gain).
There is no reason to be paying that sudiophool premium. Found audio "sleepers", starting with the 6BQ6GA -- a TV HD final where the spec sheet makes no mention of any audio use. Another one I found was the 6BQ7A -- a dual triode intended for VHF cascode operation. Nice fat cathodes for glowey bottle coolness, and they work very well as a cascode LTP phase splitter/gain stage. Enough gain to eliminate one gain stage. Not so sure how the 6BQ7A will perform as a straight triode as the plate characteristics are a bit strange, like, maybe, an undocumented variable-u characteristic? For good audio loadlines, get the VPK up. Watch out for 6BQ7s that have series connected heaters (these have a thin wire from cathode-to-cathode) these ring like bells. The 6QB7As with parallel connected heaters aren't microphonic. I get my 6BQ7s from ham meets so's I can check how the heaters are connected.
Reactions: 1 user
Those 6BQ7’s are actually nice general purpose triodes. More linear than a 12AU7. I’ve been using them as straight triode stages, as well as fancier arrangements. At low current they do become variable-mu, so I push them to 4mA or more. The ones I’ve gotten seem to be relatively quiet - haven’t noticed the microphonics you can get fron the video pentodes.
Which are extremely high gain. High gain power pentodes that will do 5 watts in push pull, many with a free triode in the bottle. So no need to go to a pair of EL84’s an a 12A*7 for a little basic 5W amp. My thought was to build a nice full featured practice amp using nothing but 6KR8’s. And call it the “Crate”. Not a single IC amp to be found, though. For hi-fi, though go the the 6KV8 because of the pretty triode. Same price, still loads to be had. I’m using those in a hi-fi preamp in development, with the KV8’s being the output balanced low-z drivers. Lots of transconductance in those pentodes. Just need enough series R (27 or 47 ohms) to isolate cable capacitance from that cathode so you do lose a bit of what you gain. I’ve made some nice TV jammers by omitting the resistors.
I got a whole box of 17BQ6’s that I thought I’d “play” with, but havent even had a chance to turn them on yet. Cute little things. TBD as to whether they’ll take 17 watt abuse. Good success on all fronts so far with all TV vertical amp tubes. Triodes and pentodes. A lot of good stuff out there for amps 10 to 30 watts, which is what the majority of tube tinkerers seem to want. Enough power to satisfy, and the transformers dont require a second mortgage (even if you’re using ones you are supposed to).
Reactions: 1 user
17BQ6GTB: Frank's. According to the spec sheet, the 17BQ6GTB is identical to the 6BQ6GTB except for the 16.8V@0.45A heater. They can handle 17.5W of static PD, which is where I bias them (VPP= 350V; IP= 50mA) for more Class A power, less x-over and improved sonic performance. The Sylvania black plate 6BQ6GTBs will handle 70mA of bias without any red glow. The RCA gray plate 6BQ6GTBs will show a trace of color at 70mA. No reason to push 'em that far and stress the PTX as well as the finals. These TV HD finals are rated very conservatively given the "brick on the key" nature of horizontal deflection: max power with a fixed waveform. Audio is far less demanding, and so spec busting doesn't do any harm.
I've been using the same 6BQ6s at 17.5W since Ought 7 and they're still going strong.
Reactions: 1 user
My thought was to build a nice full featured practice amp using nothing but 6KR8’s. And call it the “Crate”. Not a single IC amp to be found, though. For hi-fi, though go the the 6KV8 because of the pretty triode. Same price, still loads to be had. I’m using those in a hi-fi preamp in development, with the KV8’s being the output balanced low-z drivers. ...
On the subject of TV triode/pentodes, I just bought a B&O 608 amplifier and it uses ECL85 (6GV8) as the driver/output tubes and it sounds great! I can't see any problem switching to PCL85 (18GV8), or even E/PCL805, and they are all cheap and readily available here.
Reactions: 5 users
If there weren't this unconvenient (at least for the biggest part of the whole wide world ;) ) 10 pin base and the lack of JEDEC equivalents, I'd also recommend the E/PCL200: Triode absolutely the same as EC92 or half a 12AT7, power pentode comparable with EL95, but with ultra high (~22 mA/V) transconductance. Designed to drive CRT cathodes directly (= video output pentode). Could be seen as a triplet in European colour TV's up to the 1960ies end.
Best regards!
Btw: Absolutely cool B&O 608 design above! Now we should know the OT's turns ratios... And correct, especially the PCL805 is a very rugged tube!
Reactions: 1 user
A question about planning an amplifier using multiple 'P' tubes, say 4 PCL86 in a Baby Huey type design. The heater voltage should be 13.3V, so to have the heaters in series with about 54V 20VA transformer for the power supply should be fine.
1) Is this practical in real life? I know the tubes were designed for serial operation, but that was a different time when the TV repair person carried a box of replacements around. Does it degrade their performance to use them in this way over repeated use?
2) heater-to-cathode insulation. The first and last tubes have a different h-k potential, 40Vac in this case. Max Vkf is 100V, so this has to be factored in for all tubes in series.
Taking another example, UBL21, 4 of them in series is 220Vac for the heaters, so a simple isolation transformer could be used. Vkf for this tube is 150V, how did they handle this scenario in the old days?
Some old PAs I have seen just floated the heater supply with a capacitor at the end of the chain as a reference to ground.
.... how did they handle this scenario in the old days?
They connected a wire wound resistor in series. That's what the tube manufacturer prescribed. At least for the usual mix of small signal and power tubes present in a TV or Radio set.
Philips wrote what we would call an app note these days.
See section 8.2 in this document from 1972:
http://www.tubebbs.com/tubedata/sheets/010/suppinfo/Philips1972Part4.pdf
It also covers many other application and spec related issues which pop up on this forum again and again ...
including heater to cathode limits in section 9.
Reactions: 1 users
I recall my VALVO (a Philips brand/company) books Empfängerröhren 1971 (= receiving tubes) and Spezialröhren 1970 (= SQ tubes), which in their introduction tells me the sam things as in the shared document above. I like 'em.
Anyway, OldHector's concern was the heater to cathode voltage in a series heater string rather than the heater chain design itself. Out of experience that most TV producers did until ca. 1975, I'd say there's no such concern. TV heaters were arranged just with the priority of hum minimization, i. e. the AF amplifier tubes next to ground, the sweep tubes at the chain's upper end.
Note that P series tubes benefit from a capacitive voltage dropping impedance. For 300 mA, a capacitor of about 4 µF fits in almost any case. It's advantage is it's almost AC CCS property, resulting in heater soft start.
Best regards!
Reactions: 1 user
I made a spud headphone amp with 12HL7 (w/ Edcor OPTs) but found that they burn out too quickly if run at 150V plate-cathode and 35mA or higher plate current. I think their plate dissipation rating is a bit optimistic. The data sheet says 10 watts design maximum, but I couldn't get anywhere close to that. I wound up switching to 12GN7A and all is well in my spud, but if you keep the plate current down I'm sure 12HL7 would work great. I think they sound a bit better than the 12GN7A, fwiw.
Reactions: 1 user
Were those some of the RCA 12HL7 with small guts? (looking like an 11HM7 ) The "real" 12HL7 have a plate that is bigger than the 12BY7. Sylvania ones are real. RCA made some small fakes, which I sent back. Not all RCA are the small ones though.
