Sony VFET Amplifier Part 2
Any views on whether these are genuine parts?
Sven
Joined 2008
Hi All.
Just another build of Rev-2 with Teabag boards. However, now used 3 pairs of k82/j28 per channel and the Front End is powered by separate regulated PSU +/-33V from separate trafo. Also adjusted rails from +/-19 to +/-24, to be a bit closer to 40-th anniversary commemorative thing. The amp is giving 15.2V RMS before clipping at 4ohms dummy load, so it is about 58 WPC. Bandwith is narrow than original, going to moderate decline from 40kHz. Biased at 1 amp per channel.
Reactions: 10 users
