A Study of DMLs as a Full Range Speaker
For interest, I recently measured the throw of a Dayton DAEX25FHE-4 exciter at 1.1mm in and 1.4mm out.
A Dayton 3.5" TEBM65C20F BMR driver measured 2.5mm in, 2.9mm out.
So if it could be controlled, and the panel be able to bend sufficiently, the BMR driver should provide more base than the standard exciter...Yet to be tried
Hello Eucy,
Is it the maximum mechanical stroke on each direction or is it under the same amount of current?
Christian
Scrapper4 have you considered investing some time to find a commercial panel which you like? Buy a pair and reverse engineer them and when you are happy with the results of your handy work sell the commercial panels on the used market place. If you get a good deal and you don't take a long time you should not take a big hit when you sell the commercial panels off.
Steve you need to make a recording of the Coaster's playing on your coasters.
If you are referring to my canembert cheese box panel ?
This wooden panel is 11cm and the thickness is somewhere between .5mm and 1mm ?
Les than 1mm , that is as accurate as my device and eyes can go 😳
If someone has an old two way speaker with a blown tweeter, this could be a good way to have a dml speaker for free, with electronic EQ ,of course.
The XO was about 500hz if I remember correctly.
This was just a bit of fun, but it does work.
Steve.
Steve I was just getting lunch ready and stood and stared at a butcher pack of hamburger. The tray is one of those large pre moulded white styrene trays about 27.5cm long by 22.5cmm wide and 3.5cm deep at a guess the tray material is approx 3mm thick, this would hold about 1- 1.5kg of ground beef. the bottom of the tray that is flat is about 20cm x 15cm so big enough to make a flat panel say 5.5" x 7.5" close to your 6" x 9" card stock panels. Did you ever try this as a panel material? The whole tray only weighs14 grams all up. Any thoughts? This has a smooth skin, do you figure that would need to be sanded off?
