Twin Audio Full Range Speaker Kits
Folded horn cabinet for FE206En is large and very high freight cost.
Any plans to make a kit for Fostex FE206En with Folded Horn cabinet?
Would be very interested for a 2A3 SE amp...
/V
There are a few key parameters in a horn design that affects how it sounds: compression chamber size, horn length, closed-end cross-sectional area and opened-end cross-sectional area.
I have roughly estimated the parameters:
horn length: ~2.7m, should be longer
Compression chamber vol: >13L, can be tuned to taste according to Fostex
Closed-end XO area: 140cm^2
opened-end XO area:1225cm^2
With these parameters, we can engineer the horn with minimal calculations.
This sounds very interesting...
