Hey all, seeing quite a few Yaquins on Swap Meet, so thought to post mine...
Yaquin MS-110B Tube amp. 50 watts/channel. Biased set and ready to go. New-ish tubes that test very good on my tester. Comes with original manual, fancy remote and cage removal tool. Slight scratching on top from cage, but very clean condition.
Output power: 50W + 50W (6Ω)
Harmonic Distortion: ≤ 1.9% (1kHz)
Frequency Response: 10Hz - 65kHz (-2dB)
SNR: ≥ 85dB (A)
Input sensitivity: ≤ 0.3V (1kHz)
Load Impedance: 4Ω-8Ω
Tube: KT88 × 4 12AU7 × 2 12AT7 × 2
Dimensions: (length) 300mmX (W) 420mmX (high) 200mm
Weight: approximately 25 kg
Features: (from ebay ad...quite funny)
New on ebay around $1200...How about $750?
Pick up in West sub of Chicago...or can ship for $$ (55 pounds)
SNR: ≥ 85dB (A)
- Power tubes use the latest improved KT88-98 and strong output push-pull circuit.
- Preamplifier part is as "SRPP" circuit and excellent "long tail" type inverter circuit. So that a wider frequency response and better sound quality.
- Audio output transformer dedicated silicon steel imported from Japan (0.35mm thick) and oxygen-free copper wire and special high-strength multi-layer winding process grouping production (divided into 15 layers), so that the machine wide frequency response, ensuring high the machine, , the low-frequency sounds good, transparent and powerful.
- The machine adopts well-know brand dedicated audio BC capacitors and also Philipps (MKP) nonpolar capacitor.
- High quality gold-plated resistor, the main channel using a dedicated sound Japan (ALPS) volume motor potentiometer with quiet background music, noise low, no sound pollution and durable.
- High voltage power supply for the automatic delay control, can effectively extend tubes life.
- Switch between ultra-linear (UL) and three poles (TR) connection mode, to meet different user needs.
- Function with remote control and high quality headphone output.
