Picture Frame Speaker
Is your seating against the wall where these will be mounted?.......and if so,, is it a sofa or is it stand alone chairs or recliners?
I have two rows of seating. The fist row has 3 recliner chairs, the middle one being MLP. One side of the fist row is against the wall. The other side has a step up to the second row of seats that are on a platform.
The second row has 4 recliner chairs that are against the wall on either side.
If you are looking to build, and you might run music through them as well, and you have a glue gun and a box cutter knife, along with a dollar store nearby, you can hardly do better than a Cornu style. They make even a cost effective driver shine. They are also easy and a very entertaining build
How thin can these be built?
The smaller the drivers the slimmer it can be. XRK was the one who gave me suggestions on each build. He is good about responding in that thread.
@Cal Weldon
are the diamonds in the first photos there to have something more substantial to which you fasten the drivers. or ... ?
Yes. Full wood baffle and back is obviously best but a number of these were prototypes. I made them from 20” up to 48”.
Reactions: 1 user
Joined 2008
These picture frame speakers work pretty fine for nearfield listening. I think they would work well for surround as well. https://www.diyaudio.com/community/threads/dml-system-1-0.395246/post-7257014
Othewise, I would recommend my favorite FaitalPro 3FE22s in a shallow transmission line, can be made from foam board.
Dali Oberon on wall speakers sounded pretty cool on a demo as well, so I could recommend these as well.
