Yet Another Aleph J Build
:cuss: making me think!!! How about pointing me toward a schematic of the version prior to this?
I described the differences here including some of the design topology:
So a little word on some of the technical differences between the two designs. It's very easy to see that ZM has tightened up his version particularly in a more compact layout, use of cascode regulation for the input JFETs and finally some current sources. The output stage uses the Aleph CCS but with IRF 150's which provide intrinsic matching! As such it is a much more turnkey method of building an Aleph J. There is no need for matching the output devices whatsoever.
Best,
Anand.
  • Thank You
Reactions: 1 user
Official Court Jester
Joined 2003
as it seems you didn't post it, here it is, schm of built one
  • Thank You
Reactions: 4 users
Just powered up my Aleph and had a hum through the speakers, not 60Hz, very similar to my SuperNait 3 if it has an "inductance" hissy fit. Powering down, briefly, no effect. Remove the left channel RCA and that channel stopped, did the right, same, re-connected and it's gone. There is 1 other difference in the system, yesterday I connected MFF RCA's and connected my sub.
